"Error While Fetching Tile" error trying to load public Feature Layer into WebMap
1556
06-21-2021 01:09 AM
BrunoDiGiuseppe
Hello!
When I try to load a public Feature Layer hosted in ArcGIS using the JS library I get an error:
My code is basically what the documentation suggests doing. I am using ES Modules to load the map in an Angular 12 application. The following is a snippet of what i have tried(which is just what the documentation suggests):
    const webmap = new Map({
      basemap: 'arcgis-dark-gray'
    const view = new MapView({
      container: docuemnt.getElementById('container'),
      map: webmap,
      center: [-2.7319798957155292, 54.999668703716296],
      zoom: 4
    const layerView = new FeatureLayer({
        url: {{FeatureLayerURL}}
    webmap.add(layerView);
The Feature Layers shows correctly on the service definition and on the ArcGIS  Online Visualization tools.
 What seems weird is that the first request to retrieve the layer ({{url}}/FeatureServer/0) seems to  work
But then it tries to query (I am not manually setting any queries so i'm lost)
Does anyone have any pointers as to how to fix it?
Paco
Hello!   did you find a solution to this "Encountered error when fetching tile" problem?   I am now receiving this error in my application.  I changed nothing in the code,  but now takes a looong time to load Features and only pieces(tiles?) of the FeatureServices seem to draw.
hopefully you found a solution!  thx
Paco
btw,   the issue with these errors was a problem on the ESRI/AGOL Hosted Feature Service side.   once ESRI corrected the problem i had no more errors.
