Detailed/nitpicky customization of Legend
5215
11
10-09-2015 10:48 AM
ZoeZaloudek
I’m sure I’m just one line of code away from getting this to work just right!
In my code, I have a feature layer that is being symbolized with a class breaks renderer.  I also have a Legend (Dijit?).  The Title, color swatches and class labels are all showing up OK.  However, the legend is also showing what attribute field the renderer is using.  I’m guessing that I just need to add a line and use CSS (esriLegendServiceLabel?) to get this to go away, but I just can’t quite figure out what to put.
Here’s a screenshot. I circled the field name that I want not to display in light blue.
ZoeZaloudek
Well, after months of working on other things, I inadvertently stumbled upon a work-around that removed the field name from the legend.  I'm now using version 3.16.
I set the attributeField property of the ClassBreaksRenderer to a function (instead of just giving it the name of a field).
So, the line of code that creates my ClassBreaksRenderer is:
flyrRenderer = new CBRenderer(null, rendfunc0);
And the function that determines the values (located just above the renderer-creating line) is:
rendfunc0 = function(feature)  {
    var value = (feature.attributes)[field];
    return value;
I kept everything else the same - setting class breaks, symbols, etc.  And now there is no field name showing up in the legend.
This accomplishes the task I was setting out to do...  There may be a better answer out there (perhaps in JS API 4?).
RickeyFight
MVP Regular Contributor
Zoe,
Use this website to help:
Inspect and Tweak Your Pages: the Basics — Web Fundamentals
If you post the link to your site I can help more
ZoeZaloudek
OK, FIrefox has an inspector as well. I haven't used it much, but now's a good time to start, right!
Here's the link to our ENSO Comparison Tool.
SteveCole
Honored Contributor
I think you're on the right track. esriLegendServiceLabel is a CSS class so you should just be able to add an additional block of CSS into your project's CSS file:
.esriLegendServiceLabel {
    display: none;
If it's not honoring this CSS modifier, try this instead:
    display: none !important;
I tried this with ESRI's Legend demo and that eliminated the layer name like you're looking to do.
Steve
ZoeZaloudek
This was interesting.  So, I added this line to the <style> section of my htm file:
.esriLegendLayerLabel{display:none !important; }
However, the field name was still showing in the legend.
But, then I switched the version of the API I was referencing... I changed from 3.14 back to 3.13.  And that seemed to do the trick, the field name was not showing any more.  Unfortunately, I was purposely using 3.14 because can easily round/pad the decimal numbers for polygon labels in my feature layer...  So for now at least, I guess we'll just have to decide which is more important to us.
SteveCole
Honored Contributor
Whoops. I think I copied the name of the CSS class incorrectly. Switch your CSS to this:
ZoeZaloudek
Upon closer inspection, you did put ServiceLabel the first time.  I was trying LayerLabel for whatever reason.
So, I tried ServiceLabel in place of LayerLabel.  It did remove the title from the legend (August 2015, Average Temperature (°F) ), but the field name (Temp) was still there...
SteveCole
Honored Contributor
LegendLayerLabel looks more like the correct CSS class to target. I haven't used the legend widget so I don't have any experience with it so I'm basing my observations on the ESRI samples that use the widget. From what I can see in this sample, the label you want to get rid of does not have an ID or assigned a CSS class directly. The label appears to be a child element inside an HTML table which DOES get assigned the CSS class esriLegendLayerLabel.
That should work but I can't tell why it's not working for you.
ZoeZaloudek
And only using version 3.14 .  When I switch to version 3.13, the attribute field name doesn't show up.  At least this has been a learning experience, I've never really used the Inspector before.  Maybe I just need to learn to create my own Legend from scratch without using the widget.  That will probably satisfy the control freak in me   Thanks for your suggestions!
JosephPeters1
Just wanted to chime in that I was working on the same problem in the JavaScript 4.2 API and adding this to my <style> section in my html doc worked for me:
.esri-legend__layer-caption {
This thread helped me narrow a solution down and it's been on my list of things to figure out for awhile, so thanks!
