Bring back the promote functionality in the attribute table...
All your info is available to look at, at a glance. I can see how my group ranks, and how the other non selected data rank in context. Want to add something to your promoted group from the non selected group? No problem, just select a record, and press promote again. As opposed to only showing selected, this is a much better workflow for me.
I completely agree with Michael. It seems that most of the current GIS professionals never had to use ArcView 3.x, so they don't know what they are missing. The ability to select/promote/sort tabular records is incredibly useful and powerful. I used this functionality all the time when trying to clean up a join between an "outside" table and a shapefile. I don't understand why the Table functions get progressively worse with every iteration of ArcMap. It sounds odd, but to bring back core ArcView 3.x functionality would greatly enhance ArcMap or Pro. PLEASE.
I agree, if there is one feature from 3.3 that I miss it is the PROMOTE option. I use to use it all the time and wish they would bring it back. Michael Nicholas did a great job of explaining how it worked but you have know idea of the impact until you actually get to use it. Now that it's gone so many years most users today have know idea what they are missing, are even understand it and how it would help.
Create Hybrid Option Between Show all records and Selected records than once you select multiple records in the attribute table, move all selected records to the beginning of the table. ArcView 3x used to have that option. It will be a third button that will move up all selected records but also seeing the entire table.
I tried searching for info on the old “promote selected records” functionality. I didn’t find much, just this:
…the ability to promote selected records in tables instead of simply hiding un-selected records as ArcGIS offers.https://en.wikipedia.org/wiki/ArcView_3.x
In this simplified example I would select say all the houses on Main street in a two block area
The result would look something like this, showing highlighted records in a random order in the table.
Say I sorted on address then selected Promote. Promote would then move all the selected to the top of the table, and the unselected still showing but listed below the selected. Each group would be sorted by HsNo in this case. I could then scroll through the table (entire table) and look for anomalies in my selection. This was a very useful tool in AV3
Say for example you were looking for all the 6 inch and above water pipe that was NOT PVC and you set up your query like this: Size >= 6 AND Material NOT LIKE 'PVC'
In your selection is something like this:
If you sorted on Material and then promoted you could scroll through the records to find anomalies in the selected and unselected set like this!
Admittedly showing only the selected and sorting then reverse select does the same thing but this was a way to see all the records at once with selected at the top of the list.
For what it's worth, I tried mocking up something similar in Pro, just to see what it might look like.
I added the FC twice to the map:
It was pretty cumbersome to use in practice. True "Promote Selected Records" functionality is still needed.
Here's another less than ideal workaround:
Create a query layer with a FLAG field:
select objectid, case when type='NT' then 1 else 0 end as flagfrom infrastr.active_transportation
2. Join from the FC to the query layer via the OBJECTID.
3. Sort the attribute table by the FLAG field (descending).
Now, the the rows where type='NT' are at the top of the attribute table. Which is more or less what I wanted.
However, it's not a realistic solution:
Source: Specify how nulls are sorted in the attribute table (nulls first or last)
Related:
Is promote still not available in Pro?
I suspect at this point, since it has been since ArcView 3.3 (2002) since promote was available that it is not something they consider adding to ArcGIS
Looks like this idea is still open for discussion
https://community.esri.com/t5/arcgis-pro-ideas/attribute-table-quot-scroll-to-selected-record/idi-p/1274283
Posted by KoryKramer (ESRI)
@Gene_Sipes and others voting on this idea. You mention that you're looking for a capability to "scroll to selected records" that will focus your attribute table on the records you have selected on the map, so that you can view them within the context of other non-selected records.
What is you have more than one feature in the map selected and the records are "far away" (like further than a page view in your attribute table)? What is your expectation? It wouldn't logically be possible to show them all at once.
There is this idea to bring back Promote Selected Records from ArcView. There is a good use case noted here https://community.esri.com/t5/arcgis-pro-ideas/promote-selected-records/idc-p/929432/highlight/true#... Is that similar to your workflow? Could you let us know either way - whether it is or isn't? If it is, maybe it would be best to merge this idea into the other. If not, please provide some clarifying details about your workflow and how you picture this new functionality solving the problem. Thanks!"
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
