ArcGIS Solutions Blog
Other Boards in This Place
Latest Activity
(13 Posts)
RyanNosek1
If you deployed the Winter Weather Operations solution after the November 2023 ArcGIS Velocity release, you may be missing an important configuration setting in the Snow Route Status big data analytic. This article describes the issue and how to resolve it in new and existing deployments.
Read more...
more
3 0 149
ShareUser
Esri Community Manager
Intended for database administrators as recommendations for establishing the product workspaces in an Enterprise Geodatabase (Oracle®, SQL Server®, PostgreSQL®).
Read more...
more
0 0 62
ShareUser
ArcGIS Desktop (ArcMap) 10.8.2 (the latest and last version) will switch to 'Mature' support in March 2024.
That means no more software updates or patches.
ArcMap PLC - https://support.esri.com/en-us/products/arcmap/life-cycle
Read more...
more
0 0 627
JeremiahLindemann
Updated survey and report for Point-in-Time count attached
Read more...
more
8 0 998
GelisaJoseph
This blog explains the process to upgrade from Communications Data Management (CDM) version 1 to version 2. If you’ve previously deployed CDM, you are not required to upgrade to version 2.0.  You should only upgrade if you will benefit from the new capabilities and the benefit outweighs the effort.
Read more...
more
1 0 413
JaishaBurr
Here is a quick summary of what’s new in the March release of ArcGIS Solution.
Read more...
more
4 0 482
AndyShoemaker
Updates to Arcade in  ArcGIS Online causes some expressions shipped with solutions to fail. This article describes how to fix these issues after deployment.
Read more...
more
1 0 270
AlexKabak
With the rapidly approaching October 16, 2024 deadline for all water utilities in the United States to complete an initial lead service line inventory, we have had many questions about how to upgrade a previous deployment of the Lead Service Line Inventory solution to version 3.0.  This blog explains the process.
Read more...
more
0 2 1,687
ChrisFox
Changes in ArcGIS Pro 3.1 cause some attribute rules to fail. This article describes how to resolve these errors in your existing deployment.
Read more...
more
1 5 862
ChrisFox
There may be cases where you want to deploy multiple versions of a solution. For example, a county who deploys our Election Results solution for each midterm and general election to visualize and share election results with the community. Each deployment of a solution places the solution and associated items into a new folder in your content. If you deploy Election Results three times you will have three copies of each item in 3 separate folders. Renaming the folder can help you uniquely identify each solution, however when you search your content for an item it can be challenging to know which item is associated with which deployment of the solution.
To assist with this we have created a new geoprocessing tool for ArcGIS Pro that can add a prefix or suffix to all the items and groups included with a solution deployment. So for example, if we deployed Election Results for the 2020 general election we could add the prefix '2020 General' to all the items included with that deployment. If we then deploy Election Results for the 2022 midterm we could add the prefix '2022 Midterm' to all items in this deployment. Now when we search for an item we can more easily distinguish between items associated with different deployments of the same solution.
Complete the following steps to add a prefix or suffix to all items deployed with an ArcGIS Solution:
  1. Download the Solution Helper Tools and unzip the zip file
  2. Open ArcGIS Pro and sign into your ArcGIS organization.
  3. From the Insert tab click Toolbox > Add Toolbox and add the SolutionHelperTools.atbx
  4. Expand Toolboxes in the Catalog pane and open the Rename Solution Content tool in the SolutionHelperTools toolbox.
  5. In the Deployed Solution Item parameter selection the solution associated with the items you want to add a prefix or suffix to. You can also copy/paste the item id from the browser into the parameter.
  6. Add either a prefix or suffix you want to add to the item name.
  7. Click Run.
more
6 1 1,615
105 Subscribers
