This article applies to users of the Winter Weather Operations solution (current release, version 1.1) that deployed their solution after October 2023, including users that plan to deploy the solution going forward.
Other users with an existing deployment of the Winter Weather Operations solution that predates November 2023 may also want to verify the configuration settings of their Snow Route Status big data analytic as documented below.
A critical analytic configuration setting is omitted when following the steps to configure the Snow Route Status big data analytic. This is the result of a change to the user interface when editing an input node in a big data analytic in ArcGIS Velocity starting at ArcGIS Velocity release 4.3 (November 2023).
The setting omitted is the WHERE clause for the VehicleTracks layer, an input layer used in several analytic pipelines. The WHERE clause meant to be configured with this input layer limits the number of records that are processed each run time of the analytic, which is scheduled to run every three minutes, to process only a subset of VehicleTracks records produced in the last 10 minutes, based on the values in the datetimeprocessed field.
Prior to the November 2023 ArcGIS Velocity release, this WHERE clause would auto-populate for the user when following the solution’s Configure documentation, e.g. “datetimeprocessed > CURRENT_TIMESTAMP - INTERVAL '10' MINUTE”. After the November 2023 ArcGIS Velocity release, this behavior instead resets to a default WHERE clause, e.g. “1=1”.
Without this WHERE clause, the scheduled big data analytic will attempt to process every record in the VehicleTracks input layer every run time, which has a default retention period of 1 day. When considering factors such as the number of vehicles in your fleet and how frequently new tracks are being generated from your vehicle feed, an unnecessarily large number of records will attempt to be processed each run time of the scheduled analytic. This can lead to potential performance issues and/or inaccurate results in downstream pipelines and outputs for snow route status updates, vehicle track history, and distance traveled.
Follow the steps below to fix this omission in the Snow Route Status big data analytic for either existing deployments or new deployments of the Winter Weather Operations solution.
For existing deployments
Attribute | Value |
Date field for latest features | datetimeprocessed |
WHERE clause | datetimeprocessed > CURRENT_TIMESTAMP - INTERVAL '10' MINUTE |
For new deployments
Later in 2024 a new version of the Winter Weather Operations solution will account for this change in the solution Configure documentation.
