JavaScript Maps SDK Blog
238
605.1K
71
| Under Consideration | We are using the legend component from the ArcGIS SDK for JavaScript to display data organized in 3-level hierarchies... by stephengsavage Emerging Contributor 4 3 | 4 | 3 | |
| Under Consideration | In the layer list, it would be useful to be able to reorder layers using drag and drop, Move Up, Move Down, etc., but... by SparkyT19 Emerging Contributor 2 1 | 2 | 1 | |
| Under Consideration | I noticed that there is no equivalent of https://js.arcgis.com/4.33/map-components/ included in this subfolder in the... by GILBERTNG1 Occasional Contributor 3 4 | 3 | 4 | |
| Under Consideration | Support animations of glTF objects in a viewer enhances interactivity and makes 3D models more engaging and realistic... by MartinOver Occasional Contributor 0 4 | 0 | 4 | |
| Under Consideration | Referencing Area and Distance Measurement Components - Esri Community:The current Area and Distance Measurements look... by D_Atkins Frequent Contributor 1 1 | 1 | 1 | |
| Under Consideration | I am just hitting the limitation of labeling polygons which cannot be repeated:https://developers.arcgis.com/javascri... by NicolasGIS Honored Contributor 5 5 | 5 | 5 | |
| Under Consideration | We are building a web front-end to view several raster datasets, which are generally stored/served as COGs. One of t... by BillMitchell Frequent Contributor 0 1 | 0 | 1 | |
| Under Consideration | This is a request to add an enhancement to the Directions widget and this option to carry through to any instant app,... by CarmenDurham Frequent Contributor 1 1 | 1 | 1 | |
| Under Consideration | We are building an embedded map using the Sketch component and the JavaScript API.All is working fine on desktop, we ... by chitty Emerging Contributor 1 2 | 1 | 2 | |
| Under Consideration | The out of the box widget in Experience Builder includes the option for the person viewing the app to select a scaleb... by Deborah_Roth Occasional Contributor 1 1 | 1 | 1 | |
| Under Consideration | Hello,Our team has observed a potential accessibility issue with the current design of the toggle button. The toggle ... by PhucDuong Emerging Contributor 2 2 | 2 | 2 | |
| Under Consideration | I would like to see an option to have the scale selection be a dropdown with a list of standard scales, in addition t... by Justin_Greco Frequent Contributor 0 1 | 0 | 1 | |
| Under Consideration | I sometimes happen upon patch releases of the JS SDK. It’s totally possible that I’ve missed them somewhere, but I pe... by AddisonShaw Occasional Contributor 0 1 | 0 | 1 | |
| Under Consideration | Remove limitation :See : https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-FeatureRed... by FlavieMoraux Occasional Contributor 3 5 | 3 | 5 | |
| Under Consideration | With arcgis pro it is possible to add highlighted fields to the vector tiles. It would be nice if the arcgis api woul... by AntonKrijgsman Emerging Contributor 13 4 | 13 | 4 |
Idea Submission Guidelines
| User | Count |
| 6 | |
| 2 | |
| 2 | |
| 2 | |
| 2 |
