ArcGIS JavaScript Maps SDK Ideas
Other Boards in This Place
Latest Activity (153 Idea Submissions)
Sort/Filter :
Closed
In this example there are two comboboxes where the second depends on selection of the first one. In the first/left co...
SebastianKrings
by SebastianKrings Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated Friday
0 5
Closed
When using the selection-display=”fit” and selecting all but one values, the combobox correctly shows some values and...
SebastianKrings
0 5
Closed
In a combobox one can type text which leads to the suggestion list to be filtered to only show values matching the ty...
SebastianKrings
0 4
Closed
When using not using selection-display (defaults to ”all”) a new row is added to the combox when there is not enough ...
SebastianKrings
0 2
Closed
Usually using “fit” mode there are chips of the selected values fitting the space. When space runs out the “fit” opti...
SebastianKrings
0 2
Open
One of our big pushes is meeting global Accessibility requirements.Is it possible to use keyboard navigation to navig...
JonathanTiu
by JonathanTiu Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 2 weeks ago
2 0
Open
Please make Webmap layer IDs (the ID as well as the titles) editable from the webmap UI. When the webmap is used in a...
4andy
by 4andy Occasional Contributor
2 3
Open
Providing a product tailored to streamline grid editing and planning (Volue Grid Planner) we have a need for identify...
Jens_Dalsgaard
by Jens_Dalsgaard Frequent Contributor
0 3
Open
The FeatureTable widget currently uses the table from the Vaadin framework. This leads to a different user experience...
ChristianNitschkowski_AIDB
by ChristianNitschkowski_AIDB Emerging Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated a month ago
0 0
Open
It would be helpful if the FeatureTable widget (or web component) would provide slots to integrate custom content. At...
0 0
Open
For map components that contain calcite components that have a scale property, it would be great to be able to contro...
Justin_Greco
by Justin_Greco Frequent Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 10-24-2025
1 0
Open
Problem:Lets say there is a non nullable field "name" in a feature class.When creating new features using the EditorW...
SebastianKrings
5 4
Open
Background:Different data models require users to establish relationships between data in various ways. For example, ...
MariusPohl
by MariusPohl Occasional Contributor
in ArcGIS JavaScript Maps SDK Ideas Last Updated 10-21-2025
2 0
Open
Background:With scale dependent symbology it is possible to define visible scale ranges per symbology of the same Fea...
SebastianKrings
in ArcGIS JavaScript Maps SDK Ideas Last Updated 10-19-2025
6 1
6
Open
The LayerList Widget in the JS API is barely functional from scratch.As the samples in the documentation shows it can...
SebastianKrings
in ArcGIS JavaScript Maps SDK Ideas Last Updated 10-18-2025
7 0
7
222 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
