JavaScript Maps SDK Blog
238
604.1K
71
| Open | The FeatureTable widget currently uses the table from the Vaadin framework. This leads to a different user experience... by ChristianNitschkowski_AIDB Emerging Contributor 0 0 | 0 | 0 | |
| Open | It would be helpful if the FeatureTable widget (or web component) would provide slots to integrate custom content. At... by ChristianNitschkowski_AIDB Emerging Contributor 0 0 | 0 | 0 | |
| Under Consideration | Support animations of glTF objects in a viewer enhances interactivity and makes 3D models more engaging and realistic... by MartinOver Occasional Contributor 0 4 | 0 | 4 | |
| Open | ## Contour Map Visualization We tried building a contour map feature for a React/Esri JS SDK application that would d... by jacobgqc Emerging Contributor 0 2 | 0 | 2 | |
| Under Consideration | We are building a web front-end to view several raster datasets, which are generally stored/served as COGs. One of t... by BillMitchell Frequent Contributor 0 1 | 0 | 1 | |
| Open | Instead of restricting vector field symbology to predesigned types, could we enable customizable color options? I am ... by kaander08 Emerging Contributor 1 0 | 1 | 0 | |
| Open | Integrating ECharts makes it very easy to achieve some cool effects.The effect of integrating Cesium with ECharts is ... by gdnwr Emerging Contributor 0 0 | 0 | 0 | |
| Open | I noticed that during i3s requests, usually a node is accompanied by multiple requests such as geometries, textures, ... by 海洋2021 Emerging Contributor 0 0 | 0 | 0 | |
| Under Consideration | Remove limitation :See : https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-FeatureRed... by FlavieMoraux Occasional Contributor 3 5 | 3 | 5 | |
| Needs Clarification | Is it possible to add 2 arrows, a first one who represent the wind direction and strength based on an array, a second... by JohnVanMeenen Emerging Contributor 0 1 | 0 | 1 | |
| Open | Hi everyone,I wanted to bring to your attention a sample example at "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arc... by ManishGohil Occasional Contributor 0 0 | 0 | 0 | |
| Open | Enhancement featureReference Scale based scaling of Graphics in a GraphicsLayer.Enhancement categoryGraphicsLayerEnha... by SebastianFrey1 Occasional Contributor 8 1 | 8 | 1 | |
| In Product Plan | It would be helpful for some use cases to have the ability to pass different highlight options when calling a method ... by mleahy_cl Regular Contributor 1 7 | 1 | 7 | |
| Open | We're migrating our webmap from 3.x to 4.x.On the current webmap, there are several layers which need to be thematica... by nadja Frequent Contributor 8 4 | 8 | 4 | |
| Open | It should be possible to add multiple popups? view.popups = []; Add popups manually with viewHitTest -> view.popup.ad... by MichaelK1 Emerging Contributor 2 1 | 2 | 1 |
Idea Submission Guidelines
| User | Count |
| 6 | |
| 2 | |
| 2 | |
| 2 | |
| 2 |
