I have election results that are given at a block code level (block code is a collection of a couple of hundred houses more or less). Each block is assigned an 8-9 digit ID (like 153040101)
This is a short sample of the election results table.
I want to represent the election results in on a map based on any specific scenario I want. Like this:
(Shape Map Visual)
This map is from a JSON file that was prepared for ArcGIS map.
When this map file is upload on ArcGIS account and used in Power BI, I get the outlined blockcodes correctly.
But the problem is, I’m unable to display any information on these block codes (or even interact with them through any filters on Power BI – like I was able to do when I used the same map as shape map.
I have used ‘join layer’ function to join block codes from the map layer with block codes from my own data in the table. I have enabled the ‘Interact with Power BI visuals’ but it does not work.
My desired result is to get the visuals like I got when I used shape map visual but on ArcGIS.
Any help on this would be much appreciated.
