Buffer a Selected Polygon
3889
01-03-2012 07:18 AM
ChrisSergent
Here is a link to a screen recording demonstrating what I would like the code to do: http://youtu.be/mjQZXnEu1Us
Attached is the HTML document used in the recording.
The following is the code that I have written. I click on the map and it selects a polygon. From there, I want it to buffer the polygon 500 feet. Any thoughts on what is wrong with my code?
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>QueryTask with query geometry from another task</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script>
    <script type="text/javascript">
        dojo.require("esri.map");
        dojo.require("esri.tasks.query");
        dojo.require("esri.tasks.geometry");
        // Why is there no dojo.require for esri.layers.agstiled
        var map, gsvc;
        /* Initialize map, buffer, & query params */
        function init() {
            var startExtent = new esri.geometry.Extent({ "xmin": 811441.60, "ymin": 1161615.62, "xmax": 817087.15, "ymax": 1165379.33, "spatialReference": { "wkid": 3435} });
            //var startExtent = new esri.geometry.Extent({ "xmin": 778733.96207758, "ymin": 1133387.86320644, "xmax": 849794.792685476, "ymax": 1193607.08672764, "spatialReference": { "wkid": 3435} });
            map = new esri.Map("mapDiv", { extent: startExtent });
            //listen for when map is loaded and then add query functionality
            dojo.connect(map, "onLoad", initFunctionality);
            var streetMap = new esri.layers.ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/ArcGIS/rest/services/InternetVector/MapServer");
            map.addLayer(streetMap);
            gsvc = new esri.tasks.GeometryService("http://maps.decaturil.gov/ArcGIS/rest/services/Geometry/GeometryServer");
            dojo.connect(map, "onExtentChange", showExtent);
        function initFunctionality(map) {
            var queryTask = new esri.tasks.QueryTask("http://maps.decaturil.gov/ArcGIS/rest/services/InternetVector/MapServer/6");
            //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
            //If this null or not available the buffer operation will not work.  Otherwise it will do a http post to the proxy.
            esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
            esri.config.defaults.io.alwaysUseProxy = false;
            // Query for polygon excerpt
            // http://help.arcgis.com/en/webapi/javascript/arcgis/demos/query/query_bypoly.html
            // Query
            var query = new esri.tasks.Query();
            query.returnGeometry = true;
            query.outSpatialReference = { "wkid": 3435 };
            // Set the current click event to nothing
            var currentClick = null;
            // +++++Listen for map onClick event+++++
            // Fire the onClick event when the map is clicked; evt is the point on the map
            dojo.connect(map, "onClick", function (evt) {
                // Clear any graphics currently on the map
                map.graphics.clear();
                // Set the current click as the geometry to be queried and set the geometry to be queried as the point on the map that wa clicked
                currentClick = query.geometry = evt.mapPoint;
                // Set the query to determine a spatial intersect
                query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
                // Determine what polygon, based on the geometry service above intersects with the point clicked on the map
                queryTask.execute(query);
            // Set the graphic to be drawn to nothing
            firstGraphic = null;
            // +++++Listen for QueryTask onComplete event+++++
            // Fire off this function once the queryTask has completed
            dojo.connect(queryTask, "onComplete", function (graphics) {
                // Set the graphic to the polygon geometry returned in the spatial intersects query
                var firstGraphic = graphics.features[0];
                // Define the symbology for the polygon that will be displayed
                var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98, 194, 204]), 2), new dojo.Color([255, 0, 0, 0]));
                // Set the polygon to be equal to the defined symbol
                firstGraphic.setSymbol(symbol);
                // Add the polygon to the map
                map.graphics.add(firstGraphic);
                alert("I will attempt to run the buffer task.");
                // Buffer polygon
                doBuffer();
        // Custom Buffer Sample
        // http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/util_buffergraphic.html#
        function doBuffer(geometry) {
            alert("I will attempt to set the parameters for the buffer.");
            // Set up buffer parameters
            var params = new esri.tasks.BufferParameters();
            params.distances = 500;
            params.bufferSpatialReference = new esri.SpatialReference({ wkid: 3435 });
            params.outSpatialReference = map.spatialReference;
            params.unit = esri.tasks.GeometryService.UNIT_FOOT;
            gsvc.simplify([geometry], function (geometries) {
                params.geometries = geometries;
                gsvc.buffer(params, showBuffer);
        function showBuffer(geometries) {
                    new dojo.Color([255, 0, 0, 0.65]), 2
                new dojo.Color([255, 0, 0, 0, 0.35])
            dojo.forEach(geometries, function (geometry) {
                var graphic = new esri.Graphic(geometry, symbol);
                map.graphics.add(graphic);
        function showExtent(extent) {
            var s = "";
            s = "XMin: " + extent.xmin.toFixed(2) + " "
               + "YMin: " + extent.ymin.toFixed(2) + " "
               + "XMax: " + extent.xmax.toFixed(2) + " "
               + "YMax: " + extent.ymax.toFixed(2);
            dojo.byId("info").innerHTML = s;
        dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="mapDiv" style="width: 900px; height:600px; border:1px solid #000;"></div>
    <div id="info" style="padding:5px; margin:5px; background-color:#eee;"></div>
  </body>
</html>
Thanks again.
Chris S.
DanielWebb2
Hi Chris.  This post is 2 years old but I was wondering if you ever figured it out.  This is exactly what I'm wanting to do too.
JakeSkinner
Esri Esteemed Contributor
Hi Daniel,
Here is an example on how to do this:
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <title>Sample Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script src="http://js.arcgis.com/3.8/"></script>
    <script>
      var map, tb, polygon;
      require([
        "esri/map", "esri/layers/FeatureLayer", "esri/graphic", "esri/tasks/GeometryService",
        "esri/tasks/BufferParameters",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "dojo/_base/Color",
        "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/domReady!"
      ], function(
        Map, FeatureLayer, Graphic, GeometryService,
        BufferParameters,
        SimpleFillSymbol, SimpleLineSymbol, Color,
        dom, on, array
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-81.792107, 26.150807],
          zoom: 8
        gsvc = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2", {
            mode: FeatureLayer.MODE_ONDEMAND
        map.addLayers([featureLayer]);
        var highlightSymbol = new SimpleFillSymbol(
                  new SimpleLineSymbol(
                    new Color([255, 0, 0]), 1),
                  new Color([125, 125, 125, 0.35])
        featureLayer.on("click", function (evt) {
            var geom = evt.graphic.geometry;
            var highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol);
            map.graphics.add(highlightGraphic);
            var params = new BufferParameters();
            params.geometries = [geom];
            //buffer in linear units such as meters, km, miles etc.
            params.distances = [5000];
            params.unit = GeometryService.UNIT_FOOT;
          var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
              new Color([0,0,255,0.65]), 2
            new Color([0,0,255,0.35])
          array.forEach(geometries, function(geometry) {
            var graphic = new Graphic(geometry,symbol);
            map.setExtent(map.graphics.graphics[0]._extent, true);
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
DanielWebb2
Cool thanks!  That gets me started on what I want to do.
