How to toggle queryTask URL based on selected item in drop down menu?
1469
05-28-2014 11:28 AM
MatthewBaker2
Hi all,
How would I construct a queryTask URL so that it pointed to a different layer based on the selected item of a drop down?
I have 2 years worth of data I'd like to query based on the selected year in a drop down.
The URL would basically be switched to
http://arcgisserverurl/service/{layer1}
or
http://arcgisserverurl/service/{layer2}
A typical drop down menu has a label and a value... I can set the label to be the Year, and the value to be 0, 1 or whatever the corresponding layer is in the service.
Hope that makes sense!
Thanks!
-m
ManishkumarPatel
Hi Matthew,
You got all the logic pretty right on track.
You can change the queryTask.url on the change event of the dropdown or on some click of a button.
for example:
var queryTaskURLstring = "http://arcgisserverurl/service/";
on the dropdown change get the value and append that to the queryTaskURLstring
queryTaskURLstring  = queryTaskURLstring  + dropdownValue;
provide the required parameters and execute the query.
For more info on querytask please refer to the following link:
https://developers.arcgis.com/javascript/jsapi/querytask-amd.html
Hope this helps.
Regards,
Manish
ManishkumarPatel
Hi Matthew,
for example:
Hope this helps.
Regards,
Manish
MatthewBaker2
Thanks for the guidance, Manish! This seems to have worked:
<script>
  var serviceURL = "http://arcgisdev01:6080/arcgis/rest/services/Schools_Shared/MapServer/";
  var queryURL;
  //trigger function on load
  //showAlert();
  function getQueryURL() {
   var layerNum = document.getElementById("selectedYear").options[selectedYear.selectedIndex].value;
   queryURL = serviceURL + layerNum;
   //showAlert(serviceURL);
   //fill in text boxes to check my code
   document.getElementById("currentYear").value = layerNum;
   document.getElementById("fullURL").value = queryURL;
  function showAlert() {
   alert(queryURL);
 </script>
 <body>
  <select id="selectedYear" onchange="getQueryURL()">
   <option value="1">Current Year</option>
   <option value="0">Projected Year</option>
  </select>
  <input type="text" id="currentYear" size="5">
  <input type="text" id="fullURL" size="60">
  <input type="button"  value="Show URL" onclick="showAlert()">
 </body>
ManishkumarPatel
Glad to help 🙂
