Locate Button in android project
1640
04-16-2014 11:29 PM
ArowanaIndah
Hi, i'm using Locate Button sample in my android project. I save it as html file in my assets folder "file:///android_asset/index.html" and run it in my android webview. When i run it in my android, i can see the map but when i click the locate button it not working.
Did android support LocateButton widget or may be i miss something?
Thank
ArowanaIndah
I guess it about enable geolocation in a webView. There is sample in http://turbomanage.wordpress.com/2012/04/23/how-to-enable-geolocation-in-a-webview-android/ and it solved the problem.
Thank.
JonathanUihlein
This is really difficult to troubleshoot!
Were there any error messages in the console when you pressed the button?
Did you confirm that the sample works from a web-server?
ArowanaIndah
Hi thank for reply,
There is no error messages when i click the locate button in my android application and i run the sample from "http://developers.arcgis.com/javascript/samples/widget_locate/" using android browser and it show current location.
ArowanaIndah
Thank.
JonathanUihlein
Thank.
Glad you found a solution!
I figured it would be an Android issue and not a JSAPI issue 😉
