Use of variable outside queryFeatures function
1332
5
04-23-2014 10:47 AM
RyanSmith1
Hi
I have the following code to query different feature layers. I would like to know if it's possible to use the searchItems variable outsidethe actual queryFeatures anonymous function because i need to get all the results from the different layers and then attach it to one datagrid.
        layers[layerId].LayerVariable.queryFeatures(query, function (featureSet) {
            resultFeatures = featureSet.features;
                     var items = dojo.map(featureSet.features, function (feature) {
                        return feature.attributes;
                         var data = {
                             identifier: "OBJECTID",
                             items: items
                         node = dojo.byId("searchHeader");
                         var store = new dojo.data.ItemFileReadStore({
                             data: data
                         grid = new dojox.grid.DataGrid({
                             store: store,
                             structure: structure
                         node.appendChild(grid.domNode);
                         grid.startup();
SteveCole
Honored Contributor
You could have a globally declared array and every time the queryFeatures function runs, just push the features it returns into the array. Something like..
var allFeatures = {};
     dojo.forEach(featureSet.features, function(feature) {
          allFeatures.push(feature);
Steve
RyanSmith1
Steve
Hi Steve thanks for the response. I've tried that approach but the allFeatures array becomes empty after the function is completed.
JohnGravois
if you'd like to create an empty array object, you should be using brackets.  curly braces are reserved for object literals.
var allFeatures = [];
//not
not sure if that explains why what you have is empty later though..
RyanSmith1
//not
Thanks Steve, John
Turns out the global array is holding the items but code after the queryFeatures function is being executed before the actual function. Any ideas as to how i can solve this issue?
TracySchloss
Honored Contributor
You need to look through the threads searching for queryTasks and deferred.   When you execute multiple queries, you have to wait for all queries to finish before you proceed. ( In AMD-style you're searching for promise/all instead.)  It can be rather complicated to wrap your head around, but its the way you have to set it up.
