Issues with geocoding...
920
03-28-2014 08:02 AM
JaredRutledge
Greetings Everyone,
I am not as technical as most of you. I am a simple epidemiologist attempting to map data. Several weeks ago ESRI decided to disable the geocoding feature in ArcGIS and now I have to go elsewhere to geocode addresses. This is not an issue for the most part. However, when I want to display my newly geocoded addresses in ArcGIS it is no where close. I have read several threads on this issue, but I am lost.
Let's say I am geocoding this address
1221 Fulton Mall, Fresno, Ca 93721
This yielded these coordinates from Google Maps
36.73631,-119.79280
I checked display using the topographic base map in ArcGIS and it shows this dot off the coast of Africa and no where near California.
Please help me here.
Cheers,
J
ShanaBritt
Jared:
The order of the coordinates you are referencing can make a difference in how they are interpreted. It looks like the coordinates are returned as latitude (y), longitude ( x) vs longitude ( x), latitude (y). If you entered -119.76 as longitude and 36.73 as latitude you would get the location returned in California if you are using the Go To XY tool in ArcMap.
-Shana
JoeBorgione
I've said before; The G in GIS is not Google.....
