ModelBuilder window opens outside screen area
9137
7
03-10-2014 12:11 AM
by Anonymous User
Not applicable
Dear everyone,
I have just found a solution to the problem sometimes occurring with ModelBuilder window opening outside the screen area, when you open it in edit mode. This happens if you f.ex. uses a dual screen setup with the laptop docked at your office and have had the model opened on the side-screen and you then try to open the same model with the laptop un-docked using the internal screen.
What you should do is:
(1) Open the ModelBuilder window in edit mode
(2) Press <alt> <space> and then press <x>
This will maximize the ModelBuilder window to your present screen and you can then use your mouse to position the window to a new location on this screen.
Best wishes,
Peder Bøcher
Aarhus University
Denmark
Keywords: Modelbuilder window opens outside screen area, Modelbuilder window does not open
Tags (4)
StevenDel_Favero1
This worked! Thanks. It did not work in ArcCatalog, but did with ArcMap.
DavidWasserman
This recently happened to me as well. This thread was a help. Thank you.
David Wasserman, AICP
ShannaCapps
Thank you! I had this issue with a model I made on my computer that I've never used dual monitors with, and this worked!
TracyScopel
Thanks for posting this. I have one user out of a group who has this occur when he tries to open a particular model in edit mode. It's a strange problem, but it's good to have a simple fix..
ShariForbes
THANK YOU. That was maddening.
Bud
Esteemed Contributor
“…Press alt-space and then the 'm' key, which then allows you to use the arrow keys to move the dialog box back onto the screen.”
https://community.esri.com/t5/arcgis-pro-questions/arcpro-dialog-boxes-showing-up-halfway-off-screen...
https://community.esri.com/t5/arcgis-pro-ideas/open-dialog-in-same-screen-as-arcgis-pro/idc-p/139879...
Untested.
Bud
