Here is how i have done it in the past, although there is probably a better way.Basically, I create a div that holds the measurement tools.[HTML] <div id="measureWindow" style="display: none"> <div id="measurementDiv"></div> <div id="Div1"></div> <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span> </div> [/HTML]Then I use the following code to close / hide the measurement div. I also include code to uncheck all the corresponding buttons and clear the graphics from the map.var nodeMeasure = dojo.byId('measureWindow');
if (dojo.coords(nodeMeasure).h > 0) {
WipeOutControl(nodeMeasure, 300);
measurement.clearResult();
measurement.setTool("location", false);
measurement.setTool("distance", false);
measurement.setTool("area", false);
dijit.byId('btnMeasure').setAttribute('checked', false);
And here is the code that actually wipes out the div when called.//Dojo function to animate address container
function WipeOutControl(node, duration) {
dojo.fx.wipeOut({
node: node,
duration: duration
}).play();
Good luck,Mark
