Double map click events using Chrome
970
03-06-2014 11:55 AM
NevinFry
I am seeing double map click events when using Chrome.
This also results in receiving a click event after panning the map.
It appears the extraneous mouse event is being sent from _mouseClick -> _fire somewhere in the map source.
The "correct" mouse event is being fired from _fireClickEvent -> _fire.
You can see the click after pan behavior with this sample:
http://developers.arcgis.com/en/javascript/samples/map_infowindow/
Thanks.
-- James
NevinFry
I believe this issue is related to using it on a computer that also has a touchscreen.
Using the touchscreen only (and not the mouse) does not produce this behavior.
-- James
