String from index position
5550
18
03-03-2014 12:18 PM
NoahHuntington
Trying to calculate field using all the leftmost characters of [TEXTSTRING] up to the first occurrence of "out" in [TEXTSTRING] whose position has been calculated and placed in [POSITION] field.  The following is  vbscript but I'm sure there is an easy python solution to this. The script should help clarify...
[position] = first occurrence of "out" in [TEXTSTRING]
label:
Left( [TEXTSTRING], Len( [TEXTSTRING] ) [position] )
I hope this make sense?
MathewCoyle
Honored Contributor
If using field calculator try this.
!TEXTSTRING![:int(!position!)]
int() may or may not be required depending on field type of "position"
by Anonymous User
Not applicable
Do you mean splitting it up by white space and finding where the word 'out' is within a string?  If so, you could get the position with something like this:
>>> a = 'this is out at pos 2'
>>> b = 'out at pos 0'
>>> c = 'pos 3 is out'
>>> def findIndex(string, word):
 return string.split().index(word)
>>> for test in [a, b, c]:
 print findIndex(test, 'out')
I don't know much VB so I'm not sure what you're doing once you have the index?
EDIT:  Matt's answer is waaaay better than mine.
NoahHuntington
I have tried both of the following?
!TEXTSTRING![: !postion!]
!TEXTSTRING![: int(!postion!)]
by Anonymous User
Not applicable
If you are just looking to get everything before the word "out" in a text string, how about:
!TEXTSTRING!.split("out")[0].strip()
NoahHuntington
>>> b = 'out at pos 0'
>>> c = 'pos 3 is out'
No problem. Yeah I'm not sure what your testing in this one?  Thanks for chiming in Caleb!
NoahHuntington
No luck here?
MathewCoyle
Honored Contributor
Could you post a sample of your table you are trying to calculate and the applicable field types?
NoahHuntington
Hi Matt
See attached:
label using textstring only...
label does not all show in table fyi.
MathewCoyle
Honored Contributor
Are you trying to calculate a field or create a label?
