String from index position
5540
18
03-03-2014 12:18 PM
NoahHuntington
Trying to calculate field using all the leftmost characters of [TEXTSTRING] up to the first occurrence of "out" in [TEXTSTRING] whose position has been calculated and placed in [POSITION] field.  The following is  vbscript but I'm sure there is an easy python solution to this. The script should help clarify...
[position] = first occurrence of "out" in [TEXTSTRING]
label:
Left( [TEXTSTRING], Len( [TEXTSTRING] ) [position] )
I hope this make sense?
NoahHuntington
Are you trying to calculate a field or create a label?
Ultimately label.  In doing so was attempting to create new label field? Open to label expression too!
MathewCoyle
Honored Contributor
If neither of the posted samples worked for you something odd is going on with your data or how you are executing the calculator. Are you sure you are enabling Python instead of VB? What errors or messages do you get?
NoahHuntington
Matt,
position is a long, new label field and textstring are string fields...
using:
!TEXTSTRING![:int( !position!)]
received:
error 000539: exceptions.TypeError: cannot concatenate 'str' and 'int' objects.
MathewCoyle
Honored Contributor
Is that your entire expression? Can you take a screenshot of your field calculator window with the code you execute that returns that error? Also can you post the entire error message? And what version of ArcGIS are you using? Something isn't adding up here.
NoahHuntington
[ATTACH=CONFIG]31928[/ATTACH]
This is what I'm attempting?
MathewCoyle
Honored Contributor
Can you post the full error you are receiving so we can see what has been passed that causes the error? It should look something like this.
Executing: CalculateField blocks TEST_LABEL "!SOURCEID![:  !TEXT_INTS! ]" PYTHON_9.3 #
Start Time: Tue Mar 04 12:48:53 2014
ERROR 000539: Error running expression: u"FA07908426251"[:  u"2014" ]
  File "<expression>", line 1, in <module>
TypeError: slice indices must be integers or None or have an __index__ method
Failed to execute (CalculateField).
Failed at Tue Mar 04 12:48:53 2014 (Elapsed Time: 0.04 seconds)
You can find it under the 'Results' tab
NoahHuntington
Messages
Executing: CalculateField OWNERSHIP_TEXT Label "!TEXTSTRING![:int (!postion!)]" PYTHON_9.3 #
Start Time: Tue Mar 04 16:55:32 2014
ERROR 000539: SyntaxError: EOL while scanning string literal (<expression>, line 1)
Failed at Tue Mar 04 16:55:32 2014 (Elapsed Time: 0.10 seconds)
MathewCoyle
Honored Contributor
That is an error with the expression format itself. Double check your field names and that you are using Python instead of VB.
NoahHuntington
If I ran yesterday according to the picture provided at 11:18 where do you suppose I went wrong? FYI: [postion] although misspelled is the actual field name...
