Wrong Column Type
936
02-17-2014 02:46 AM
BerkUlupinar
I created a tablespace and a table into this tablespace in oracle spatial. (11g) After that,i connect this database from ArcCatalog.When i want to add this table to table of contents, ArcGIS gives me a warning : "Could not add specified data ojbect to the map.Wrong Column Type(ınvalid geometry storage type)"
How can i solve this problem?
Thanks for helping.
VinceAngelo
Esri Esteemed Contributor
You could help yourself by providing the information necessary to answer your question:
    • Which exact Oracle release are you using (11.x.y.z)?
    • What exact version (and service pack) of ArcGIS are you using?
    • Have you enabled a geodatabase in the instance, or are you using a Query Layer?
    • How exactly is the table defined? (Provide SQL*Plus DESCRIBE output or your
      CREATE TABLE command)
    • How have you populated the SDO_GEOM_METADATA table row associated with this table?
    • Have you built an index on the geometry column?  If so, what exact command did you use to build it?
    • Which column did you specify as the rowid column?
    • Are all the non-nil geometries in the table either point, multi-point, line, or area features?
Note that "Oracle Spatial" is not a storage format -- It's an application suite.  The storage
format is SDO_GEOMETRY.
- V
EmadAl-Mousa
you need to register the oracle spatial layer with SDE Geodatabase.
check this as a refrence: http://support.esri.com/cn/knowledgebase/techarticles/detail/20275
VinceAngelo
No, with Query Layers, ArcSDE registration is no longer required. -V
