Near Table without using FID
1814
10-10-2013 03:48 AM
ToniBrugués
I have 2 layers and I want to calculate the distance between the points of one layer and the points of the other (n to n). So I generate the near table but it uses FID field but I'd like to use another field. How can I do that?
thank you.
ChristopherBlinn1
I'm working with zip codes, so I'd like to use these zip codes instead of the ID
The near calculations are still valid, you just need to get your zip code values into the near table results.
You could use the Join Field to add the Zip Code field from each point feature class to the near results.  The FID's will match to the OID's of each point feature class.
Hope this helps!
Best,
Chris B.
ChristopherBlinn1
Toni,
Why exactly would you like to use a different field?
Just let us know.
Chris B.
ToniBrugués
Toni,
Just let us know.
Chris B.
ChristopherBlinn1
Hope this helps!
Best,
Chris B.
ToniBrugués
Ok, my fault.
I thought about the join, but the opposite one, losing all the distances except one for each zip code.:rolleyes:
I need to focus!
thank you!
