Geoprocessing Task with No Parameters?
1156
10-03-2013 07:41 AM
ionarawilson1
Is it possible to run a geoprocessing service (gp task) in a web app without passing any parameters? If so how would I change the submitjob function to have no parameters
gp.submitJob(params, completeCallback , statusCallback,function(error){ //          alert(error);
RyanClancy
I'm going to assume we're talking about the Javascript API. As per the API documentation, inputParameters are required for the submitJob method. If you don't want to pass anything you could just have
var inputParams = ""; gp.submitJob(inputParams.....
...provided that the corresponding GP service doesn't actually require any input parameters. In this case I suppose you'd have things like the input data parameter hardcoded into the underlying Python script?
RyanClancy
ionarawilson1
Thank you Ryan. I will try that. Yes, I have it coded in Python. I will also try submitting with one parameter. Thanks
