Graph Labels NOT Showing Correctly
2056
09-10-2013 08:21 AM
ModernElectric
Having issues with the titles (X-Axis) and (Y-Axis) in my graphs not working properly. I have it set in a Python script to make it "KWH_USAGE" but when the graph is created - it shows "kwh_usage"... Why is it only showing everything as lower case?
Also - I want to include the data from a specific field in a feature class to show in the title. So if I have 14884512 in a field called "TWACs_Number" - I want the title to include that. How would I write that?
Thank you
JakeSkinner
Esri Esteemed Contributor
Chris,
I believe I was assisting your before.  I think the title of the axis's being lowercase is a bug.  I was able to reproduce this same behavior.  I would recommend following up with Tech Support.
As for the title, you can use the 'getValue' method to retrieve the value of your field.  Ex:
import arcpy from arcpy import env env.overwriteOutput = 1 env.workspace = r"C:\temp\data.gdb"  table = "Meters"  fields = ["METER_NUMBER"]  list = []  rows = arcpy.SearchCursor(table) for row in rows:     list.append(row.METER_NUMBER)  del row, rows  #remove duplicates from list list = dict.fromkeys(list) list = list.keys()  for n in list:     arcpy.TableSelect_analysis(table, r"in_memory\table_sel", "METER_NUMBER = " + str(n))          #get TWACs_Number value     for row in arcpy.SearchCursor(r"in_memory\table_sel"):         TWACs_Number = row.getValue("TWACs_Number")          out_graph_name = n     out_graph_pdf = r"C:\Temp" + "\\" + str(n) + ".pdf"     input_template = r"C:\Temp\KW Demand.grf"     input_data = r"in_memory\table_sel"      # Create the graph     graph = arcpy.Graph()      # Add a vertical bar series to the graph     graph.addSeriesBarVertical(input_data, "KW_DEMAND")      # Specify the title of the left axis     graph.graphAxis[0].title = "KW Demand"      # Specify the title of the bottom axis     graph.graphAxis[2].title = "Meter Number"      # Specify the title of the Graph     graph.graphPropsGeneral.title = TWACs_Number      # Output a graph, which is created in-memory     arcpy.MakeGraph_management(input_template, graph, out_graph_name)      # Save the graph as a PDF     arcpy.SaveGraph_management(out_graph_name, out_graph_pdf, "MAINTAIN_ASPECT_RATIO", 600, 375)
JakeSkinner
Chris,
ModernElectric
Jake-
Yes - huge help on one of my previous posts to get the Python script to create the graph. Nice to know that there is a bug in the tool/script. I have been trying multiple different things for the past few days to get it to work. I will send a note to Tech Support and see what can be done. Thank you for the help.
Chris
Chris,
import arcpy
table = "Meters"
list = []
for row in rows:
del row, rows
list = list.keys()
for n in list:
    out_graph_name = n
    # Create the graph
FredGifford
Just ran into the same problem and am wondering if there is a workaround?
Thanks.
Fred
