infoWindow does not open on initial load of line and polygon feature layers
421
08-30-2013 07:08 AM
deleted-user-ugCMpXci8bn5
I am using a popup infoWindow with Feature Layers.
When initially loaded, the infowWindow pops up as expected for point layers, but it does not pop up immediately for line and polygon layers.  If I zoom in or out after the initial load, the infowWindow then works as expected.
How can I change this, so that the infoWindow opens on the first click for all the layer types?
code below, thanks, Jason
map constructor:
var infoWindowPopup = new esri.dijit.Popup(null, dojo.create("div"));
    map = new esri.Map("map", {
        extent: startExtent,
        infoWindow: infoWindowPopup
example: point layer (infoWindow works as expected on initial load):
           pointLayer = new esri.layers.FeatureLayer("http://[server]/ArcGIS/rest/services/[pointLayer]/MapServer/6", {
              //  opacity: 0.9,
                mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
                infoTemplate: infoTemplate1,
                outFields: ["*"]
example: line layer(infoWindow does not open on click, on initial load):
            lineLayer = new esri.layers.FeatureLayer("http://[server]/ArcGIS/rest/services/lineLayer/MapServer/7", {
                id: " lineLayer",
               // opacity: 0.9,
                outFields: ["*"]
