Model builder - buffer tool
2256
05-20-2013 09:41 PM
ThillaiNadarajan
Hi
I am interested in creating a model with buffer tool . My requirement is to provide the distance by the user at the time of executing the model. It means that it should ask for the DISTANCE for the user to enter.
So that I can give different values each time i run the model.
Thillai
EjayLai
Hi
Thillai
Here are the steps:
1. Create a model
2. Drag the Butter (Analysis) tool to the model
3. Provide an input feature/shapefile to be buffered, where to save it and rename them if necessary...
4. Right-clicking the Buffer tool and select Make Variable > From Parameters > Distance
5. Distance parameter will be created, right-click on it and select Model Parameter (that's the magic touch!)
6. Save it and close it
7. Open it from where you have saved to and it will ask you for a distance
Hope this helps!
ThillaiNadarajan
Hi Harry,
Thank you for giving me the steps. It works.
Regards
Thillai
EjayLai
Hi Harry,
Regards
Thillai
You are welcome. But please mark it "as answered" so that the red flag will be removed otherwise others may thought it is a 'cold case'!
AdamRobbins
Great response.  This is just what I was looking for.  I actually wanted to know one additional thing though.  Is this applicable for an arcGIS online map?  For instance, I've created a map and I want to embed it onto my website.  When the user comes to my website, I want them to be able to input their address, which will then feed into a model which will generate a 500 mile buffer around that location automatically.  Is this even possible on arcGIS online?
