query.where issu
3362
12
05-14-2013 02:42 AM
khadijaahal_el_fadl
Hi , i try to query  on more than one field, I want to have somthing like
"query.where= "field1='"+value1+"'" && "field2='"+value2+"'" ; but it doesn't work, it consider just the last field :it works as it was one only field wich is the last one.  if you have Any idea please
KenBuja
MVP Esteemed Contributor
Try this instead
if( val1&&val2){q.where="p_from='"+val1+"' AND p_to='"+val2+"'";}
VinayBansal
Try putting "AND" instead of "&&" in where clause
khadijaahal_el_fadl
thank you for replying , but I had already tried it and it doesn't work too.
ReneRubalcava
Esri Frequent Contributor
Is that your exact query?
This query.where= "field1='"+value1+"'" && "field2='"+value2+"'" is a boolean expression, true or false.
Is this the exact code you are using?
It should be formed as query.where = "field1='" + value1 + "' AND field2='" + value2 + "'"
Try to test it via the Query REST page and see if it works as expected.
khadijaahal_el_fadl
Hi,thank you for replaying. I tested the  query as you suggested  in the REST page and I had an error:
  "error" :
    "code" : 400,
    "message" : "Unable to complete  operation.",
    "details" : [
      "Unable to complete Query operation."
ReneRubalcava
I think if a field value is numeric, you can eliminate the single quotes, could be an issue. Tough to diagnose without looking at the data. How about if you do one query a time, without trying to combine them?
khadijaahal_el_fadl
I teied this  on the rest page :
field1='value1' AND field2='value2'
and it works
khadijaahal_el_fadl
the problem is that when I use the "AND" in JS code , it's not recognized. Have you any idea about that?
KenBuja
Can you post what isn't working in your code?
khadijaahal_el_fadl
var val1=this.widgets.textSearch.getValue();
var val2=this.widgets.exp.getValue();
if( val1&&val2){q.where="p_from='"+val1+"'" &&"p_to='"+val2+"'";} "
I've tried to replace "&&" withe "AND" but still not working
