query.where issu
3387
12
05-14-2013 02:42 AM
khadijaahal_el_fadl
Hi , i try to query  on more than one field, I want to have somthing like
"query.where= "field1='"+value1+"'" && "field2='"+value2+"'" ; but it doesn't work, it consider just the last field :it works as it was one only field wich is the last one.  if you have Any idea please
KenBuja
MVP Esteemed Contributor
Try this instead
if( val1&&val2){q.where="p_from='"+val1+"' AND p_to='"+val2+"'";}
khadijaahal_el_fadl
Try this instead
thank you so much ,It works finally thanks to you 🙂
KenBuja
Gald to help. When you run into problems like this, you should use the debugger to see how the where clause is interpreted by the code.
Don't forget to click the check mark on the post that best answered your question.
