Sorting FilteringSelect
4379
04-16-2013 07:00 AM
SamirGambhir
I have a data store with names of states queried from a feature layer as shown in this example. Here is my code:
//Populate the ComboBox with unique values  var stateName;  var values = [];  var testVals = {};   //Add option to display all district names to the ComboBox  values.push({   name : "All India"  });   //Loop through the QueryTask results and populate an array  //with the unique values  var features = results.features;  dojo.forEach(features, function(feature) {   stateName = feature.attributes.State_name;   if (!testVals[stateName]) {    testVals[stateName] = true;    values.push({     name : stateName    });   }  });  //Create a ItemFileReadStore and use it for the  //ComboBox's data source  var dataItems = {   identifier : 'name',   label : 'name',   items : values  };   var storeS = new dojo.data.ItemFileReadStore({   data : dataItems  });
This data store is attached to a filteringSelect:
dijit.byId("selStateM2").set("store", storeS);
Before ataching the store to my filteringSelect, I would like to sort the state names in alphabetical order. Here is my code:
var sortAttr = [{   attribute : "name",   ascending : true  }];  storeS.fetch({   query : {},   sort : sortAttr });
I need help in understanding how to push this sorted list to my filteringSelect.
Samir
SteveCole
Honored Contributor
I specify the sorting over on the HTML side of things for filteringSelect by adding the following:
searchAttr="<your field name>" fetchProperties="{sort:[{attribute:'<your field name>', descending:false}]}"
The full HTML reference looks like this:
<input id="cboCrossStEnd" dojoType="dijit.form.FilteringSelect" checked="checked" searchAttr="CROSSST" name="WidgetName" pageSize="6" fetchProperties="{sort:[{attribute:'CROSSST', descending:false}]}" placeHolder="Select a road from the list" onChange="<your function here>" />
Here's my JS code for populating the filteringSelect (this is triggered via dojo.connect during the onLoad event):
function populateRdNameCbo(results) {  //Populate the dropdown list box with unique values  values = [];     testVals = {};    features = results.features;  dojo.forEach (features, function(feature) {   curName = feature.attributes.FULLNAME;   if (!testVals[curName]) {    testVals[curName] = true;    values.push({"OBJECTID":feature.attributes.OBJECTID,"RDNAME":feature.attributes.FULLNAME});   }  });    dataItems = {      identifier: "OBJECTID",      label: "RDNAME",      items: values  };    theStore = new dojo.data.ItemFileReadStore({data:dataItems});   dijit.byId("cboRdName").set("store", theStore);  }
My code also eliminates duplicate entries as it adds items to the list. Seems to work for me.
SteveCole
Honored Contributor
SamirGambhir
Thanks Steve,
It worked for me as well. The next thing I need to do is to sort the html list that is displayed after user selects state(s).
Samir
