Can you force RouteTask to use a specific street?
1445
04-09-2013 07:15 PM
SteveCole
Honored Contributor
I just started playing with routeTask and, although it works great, it can produce some unintended routes. I can't see an obvious way to do this so I'll just ask- can you specify a parameter to the route task so that any route that is calculated MUST utilize a specific street?
I'm considering using the routeTask to help map road segments by specifying the starting and ending locations. The problem occurs if there's a major road that parallels the actual road I want because the calculated route will jump onto the major road instead of following the local road. In my simple tests, the route task would create the route I wanted if I was able to add another stop along the road I'm interested in and between the two end points.
Thanks!
Steve
SteveCole
Honored Contributor
*bump*?
Thanks!
Steve
JohnGravois
looking through the REST help for the Solve operation, it doesn't look like it.  there seem to be more options for restrictions than for "forcing"
SteveCole
Honored Contributor
Thanks, John. The documentation for routeParam is pretty vague so I wasn't sure about that. I think as a work around, I'll prompt the user to click along the desired street and then add the clicked point as a third stop along the desired route.
