Adding KML file in map control by JavaScript API
4692
02-19-2013 05:53 AM
AmmarAssem1
I Have kml file and i need to display it into map control by using javascript api.
In this example http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/#sample/layers_kml
kml file already published in server when i replace kml url in server by url in my local disk but not work
KellyHutchins
Esri Notable Contributor
Locally hosted kml files are not supported. The kml must be available via  a publicly accessible url. See the API reference for the KML layer for details:
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#kmllayer
NitinShinde
I have KML accessible by public IP. but still I am not able to overlay KML on the basemap. "it is giving error spatial reference mismatch. cannot change it at client side."
Then I assigned spatial reference to kml layer as per basemap spatial reference but still not able to overlay.
Plz suggest
derekswingley1
Please the code you're using to create your KML Layer.
