Identical values in a field
1459
6
04-12-2013 12:33 PM
JerrySmart
I have multiple identical values within a field in an attribute table and would like to delete them.  I am using ArcEditor version 10, sp5.  I tried to use the Delete Identical tool in Python but get the "you are not licensed for this tool" message.  there must be another way to accomplish this that I am not aware of.  Any help would be appreciated.
MelanieSummers
The Delete Identical Tool is only available at the ArcInfo license level which is why you are getting that message. Do you want to delete the features or just the values in the attribute table? Do you want all identical values to be deleted or to only delete one of them?
Best,
Melanie S.
JerrySmart
Best,
Melanie S.
I would like to delete all but one of the duplicate features and values.
Thanks.
MelanieSummers
Do you care which one is deleted?
Melanie S.
JerrySmart
Mostly, no, but there are a few that could be a problem.
MelanieSummers
Attached in a python script that will select all duplicate records. This will at least ID which ones you need to go through, I would not suggest automating the deleting process as you are not sure which one needs to be deleted.
Best,
Melanie S.
JerrySmart
Thank you very much for your help.
