I love your solution, great work!I tried modifying it to my own needs, using the WMS service from Open Weather Data. The layer is displayed correctly (look for the black lines, the Isobars), but aren't printed. Any thoughts on why that happens? <!doctype html>
<html>
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">
<title></title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/esri/css/esri.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; }
.shadow {
-moz-box-shadow: 0 0 5px #888;
-webkit-box-shadow: 0 0 5px #888;
#map{ margin: 0; padding: 0; }
#feedback {
background: #fff;
color: #000;
position: absolute;
font-family: arial;
height: auto;
right: 30px;
margin: 5px;
padding: 10px;
top: 30px;
width: 300px;
z-index: 40;
#feedback a {
border-bottom: 1px solid #888;
color: #444;
text-decoration: none;
#feedback a:hover, #feedback a:active, #feedback a:visited {
border: none;
color: #444;
#note { font-size: 80%; font-weight: 700; padding: 0 0 10px 0; }
#info { padding: 10px 0 0 0; }
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/"></script>
<script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.layers.wms");
dojo.require("esri.layers.FeatureLayer");
dojo.require("esri.dijit.Print");
var app = {};
app.printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task";
function myFunction()
esri.config.defaults.io.proxyUrl = "/proxy/proxy.ashx";
urlwms = "http://wms.openweathermap.org/service";
var wmsLayer = new esri.layers.WMSLayer(urlwms, {
"type": "wms",
"transparentBackground":true,
"visibleLayers":"pressure_cntr",
"version": "1.1.1"
wmsLayer.setImageFormat("png");
app.map.addLayer(wmsLayer);
function init() {
var initialExtent = new esri.geometry.Extent({"xmin":1265873.30, "ymin":4392682.98, "xmax": 2060818.40, "ymax": 4759580.72,"spatialReference":{"wkid":102100}});
app.map = new esri.Map("map", {
basemap: "hybrid",
extent: initialExtent,
zoom: 8
// get print templates from the export web map task
var printInfo = esri.request({
"url": app.printUrl,
"content": { "f": "json" }
printInfo.then(handlePrintInfo, handleError);
function handlePrintInfo(resp) {
var layoutTemplate, templateNames, mapOnlyIndex, templates;
layoutTemplate = dojo.filter(resp.parameters, function(param, idx) {
return param.name === "Layout_Template";
if ( layoutTemplate.length == 0 ) {
console.log("print service parameters name for templates must be \"Layout_Template\"");
return;
templateNames = layoutTemplate[0].choiceList;
// remove the MAP_ONLY template then add it to the end of the list of templates
mapOnlyIndex = dojo.indexOf(templateNames, "MAP_ONLY");
if ( mapOnlyIndex > -1 ) {
var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
templateNames.push(mapOnly);
// create a print template for each choice
templates = dojo.map(templateNames, function(ch) {
var plate = new esri.tasks.PrintTemplate();
plate.layout = plate.label = ch;
plate.format = "PDF";
plate.layoutOptions = {
"authorText": "May by: Esri's JS API Team",
"copyrightText": "<copyright info here>",
"legendLayers": [],
"titleText": "Pool Permits",
"scalebarUnit": "Miles"
return plate;
// create the print dijit
app.printer = new esri.dijit.Print({
"map": app.map,
"templates": templates,
url: app.printUrl
}, dojo.byId("print_button"));
app.printer.startup();
function handleError(err) {
console.log("Something broke: ", err);
dojo.ready(init);
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit.layout.BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="map"
data-dojo-type="dijit.layout.ContentPane"
data-dojo-props="region:'center'">
<div id="feedback" class="shadow">
<h3>
Print Templates Using Layer WMS
</h3>
<button data-dojo-type="dijit.form.Button" onclick="myFunction()">WMS Layer</button>
<div id="info">
<div id="note">
Note: This sample uses an ArcGIS Server version 10.1 export web map task.
</div>
<!-- that will be used for the print dijit -->
<div id="print_button"></div>
</div>
</div>
</div>
</div>
</body>
</html>
