Map Configuration
2533
02-15-2013 05:57 AM
MikeJohnson2
Greetings,
I have created/defined a map to use with Workflow Manager.   The map has been defined and embedded in the database in the connection settings in Workflow Manager Administrator and linked to the job types for both the AOI Map and Template Map.   The problem is that the  map is not being displayed in the Map View tab in Workflow Manager.  I have also looked in the JTX_MAP_STORE and the entry for the map exists.
Is there something else that needs to be done?
Any suggestions as to the cause for the map not being displayed is appreciated.
Mike
AlisonGaiser
Mike,
The map in use by the Map View tab is set in another location (at least at 10.0). If you select Setting from the top menu and then Workflow Manager System Settings, an interface will open. There should be a Map Views tab where you can define the Job Result Map View.
I hope this is what you were looking for.
Alison
MikeJohnson2
Mike,
Alison
Thanks Alison.
