AGO Flickr feed via Social Mapping template
561
01-29-2013 06:42 AM
BartZwemmer
I must be missing something very obvious, but my map simply wont display the Flickr pictures.
I mada a basemap and stored it in My Content. After that I opened it, and via Share turned it into an application. I downloaded the application.
In config.js I added the neccesary details, then back again in My Content I went to my application, attached the new config.js (kept the same filename).
As you can see, there are no Flickr images, while they should be there. If I go to the Flickr Map, and enter the same search string, it does show them.
Anyone has an idea?
MikeMinami
Esri Notable Contributor
I see one flickr point on the map and there is a picture in the popup of someone taking a picture of himself (I assume that's you :-). Are you still having trouble?
Mike
BartZwemmer
Mike, Indeed, tha's me. So it's working now.
Come to realize, I added the tags yesterday just before configuring the app. I guess, it Flickr might not have synchronized everything. Or the reboot of my system resettet the cache completely.
Thanks for checking anyway.
