Error: xhr cancelled in IE8 using esri.request
744
12-12-2012 10:27 AM
ReneRubalcava
Oddly enough, I just saw this thread right now and found I am having the same error with something I am working on right now, but a different scenario, so I made a new thread.
This only happens in IE8, which is what I need to support in my office. It works fine in Chrome and FF, so I'm not sure what the problem is.
I am using esri.request to submit parameters to a non-arcgis web service. However, in IE8 it is appending the parameters the application pages URL and refreshing the page when I send the request.
I am using a dijit/form to collect and submit data on a (non-submit) dijit.form.button. I can tell it's not the form submitting because I can see my console debugs before the request happens.
Here is the onClick event handler for my form.
_onFlowTraceClick: function(e) {
 e.preventDefault();
 e.stopPropagation();
 var form = registry.byId('flowTraceForm');
 var data = form.getValues();
 console.log('values?', data);
 var _this = this;
 var url = '/csdapi/api/flow/trace';
 var params = {
  direction: data.direction,
  districts: data.nodetype === 'districts'
 var len = data.status.length; // an array of checkboxes
 while(len--) {
  params[data.status[len]] = true;
 console.log('params for trace', params); // I see all debug consoles up to here
 var request = esri.request({
  url: url,
  content: params
 request.then(function(response, io) {
  console.log('got a response!', response, io);
  response.bubble = true;
  response.cancelable = true;
  _this.emit('flowTraceResults', response);
When it reaches the esri.request() line it appends the parameters to the pages URL, so my app can be http://testgis/demo
and it turns into http://testgis/demo?id=999&nodetype=local&direction=up and my page refreshes. It's just weird.
*edit, it looks like it might be the form.getValues() causing an issue, because the params it adds to my URL match the form and not the custom params I make.
I do have a proxy.ashx set up with mustMatch=false for dev purposes and I can see it working in Chrome and FF.
Has anyone else seen this happen before?
ReneRubalcava
Ok, got it.
My widget template had the following as the html template for my button.
<button data-dojo-type="dijit.form.Button" data-dojo-attach-point="buttonWidget"
                  data-dojo-attach-event="onClick:_onFlowTraceClick">Trace</button>
I have to add button="type" to that or it defaults to a type of submit, which only seems to affect IE at least version 8.
I guess I just needed to write it down to work it out. Maybe this will help someone else that comes across this problem.
