Zoom in Zoom out
1011
11-26-2012 04:15 AM
JoseSanchez
Hi all,
Where is the Zoom In/ Zoom out control located?
How can I customize it?
for example in these layouts it is very different
http://help.arcgis.com/en/webapi/javascript/arcgis/samples/layout_fullmaplayout/index.html
http://thinkmaps.net/puzzle/index_en.html
KoenVermeer
In those examples you can zoom in/out with the mouse scrollwheel or by clicking on the slider in the topleft.
If you want real tools to this and drag zoom rectangles and such you can custom build these like in this example: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/toolbar_naviga...
CraigMcDade
there are several samples that give different customization options for the zoom slider. They are under the "map configuration" drop tree on the left side.
Using the links you provided  you can also Shift+Drag Mouse to create a zoom box.
TONGSUN
I need to customize zoom slider to zoom in like how toolbar navigation zoom in button works.  But all the links above don't go anywhere anymore.  Can you update the links or give some codes to just demo how it's done?
