Using Geoprocessor to add fields
2551
05-26-2010 09:55 AM
LuisPenedo
I'm trying to add fields ussing this code:
                    GeoProcessor GP = new GeoProcessor();
                    GP.AddToolbox("C:/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx");
                    GP.SetEnvironmentValue("workspece", pWorkSpace.PathName.ToString());           // 1
                    // Generate the array of parameters.
                    IVariantArray parameters = new VarArrayClass();
                    for (int f = 0; f < newFields.Count; f++)
                        parameters.RemoveAll();
                        parameters.Add(@"D:\SaltLakeCity_Sts.shp");
                        string fieldName = "FIELD_" + f;
                        parameters.Add(fieldName);
                        parameters.Add("TEXT");
                        GP.Execute("AddField_management", parameters, null);    //  2
I was getting this error after executing or attempting to execute line //   2
Error HRESULT E_FAIL has been returned from a call to a COM component.  ESRI.ARCGIS.Geoprocessing
when adding line //  1 to try to solve the problem, I got the same error message when the program tried to execute line //  1
Any ideas?  I have not used the geoprocessor with arcobjects before (this is the first time).
Thanks in advance for any help.
Luis F. Penedo
LuisPenedo
I corrected a typo but still getting the same error after attempting to update using GP.Execute
                    GP.SetEnvironmentValue("workspace", pWorkSpace.PathName.ToString());
                        //layerTable.AddField(newFields);
                        parameters.Add("SaltLakeCity_Sts.shp");
                        GP.Execute("AddField_management", parameters,null);
ThavitinaiduGulivindala
Relace "AddField_management" with "AddField" in the following line
Cheers,
Thaviti
