Labeling on layers and editing
3202
10-15-2012 07:06 AM
RobertZargarian
I am converting an ArcMap extension client application based on Arcobjects to ArcGIS Runtime WPF.
We have an .mxd file with labeling even defined in label Expressions in ArcMap. I Create an .mpk file from this .mxd in ArcMap.
When I add an ArcGISLocalDynamicMapServiceLayer from .mpk file than labeling works fine.
As I understood labeling is not supported with ArcGISLocafFeatureLayers. I am going to implement selecting and attribute and geometry editing on most of the layers in .mpk.
I consider to have ArcGISLocalDynamicMapServiceLayer in background for best rendering and create transparent ArcGISLocafFeatureLayers or GraphicsLayers for each layer.
What is the best practice here?
Robert
RobertZargarian
Anybody have any idea how to preserve map labeling, the same as it is in .mxd, and have FeatureLayers or GraphicsLayers for editing on map?
MichaelBranscomb
Esri Frequent Contributor
The workflow for this is to create a LocalFeatureService, which will spawn both the feature service and the parent map service then add a ArcGISLocalDynamicMapServiceLayer for display using the local map service and add an ArcGISLocalFeatureLayer using the local feature service with the Mode property set to SelectionOnly.
There's a SilverLight sample which demonstrates this: http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#EditToolsSelectionOnly.
Cheers
Mike
RobertZargarian
Hi
I have ArcGISLocalDynamicMapServiceLayer  and localFeatureLayers defined for every layer I want to edit.
This works fine when I make selection and display selection. But the problem is when for example user
selects a polygon and cuts it.
I cut selected polygon in localFeatureLayer. If I save changes in localFeatureLayer and update the
ArcGISLocalDynamicMapServiceLayer then it can work.
But how can I refresh ArcGISLocalDynamicMapServiceLayer in the background without saving changes
Robert
MichaelBranscomb
We are working on a labeling design which will eventually be rolled out across the ArcGIS Runtime SDKs (excluding WPF) - you can see a preview of this in the new ArcGIS Runtime SDK for .NET beta, although in the beta it is quite a limited API. Therefore we welcome input e.g.:
- Types of layers/objects you would like to label?
- Placement control you need?
- Display properties you would like to set?
- Behavior you would like the labels to exhibit?
- Interaction you expect to be able to have with labels in the map?
You can email me on mbranscomb@esri.com if you would prefer to contact me directly.
Cheers
Mike
