Submodel output in main model
1590
09-10-2012 06:23 PM
EllaGeddes
Hi Everyone,
I have constructed a series of 4 submodels that I am wanting to join together in the main model, except when I place the submodels into the main model the output variables of the submodesl are not added (even after running the submodels). Anyone know how to rectify this?
I am using ArcGIS Desktop 10.0.
JonathanQuinn
Esri Notable Contributor
Following Duncan's suggestion, in case they don't appear after dragging and dropping the sub models into the main model, right click on the submodel within the main model and select Make Variable > From Parameter and choose your output variable.
DuncanHornby
MVP Notable Contributor
Ella,
Have you exposed the outputs of your sub-models as parameters? You need to do that in each sub model then when you drag 'n' drop into the master model they will appear so you can link them.
Duncan
JonathanQuinn
EllaGeddes
Thanks so much both of you.I've got it all working now - Cheers
