Popup ??? Display Multiple Features from a Point
1359
08-27-2012 07:08 AM
GordonBooth
I created a popup with help from this forum that displays results from a Find task and also from a selection in a Data Grid. However many of the points in the results will have multiple features (i.e. multiple persons living at the same address) and only the top feature is displayed. How do I display all results from the same point? I�??ve reviewed all of the samples from the resource center and most of the posts referencing popups but I haven�??t found an example that has helped. Since you cannot access my server, I�??ve attached the Find Results in Data Grid with the code I�??m using to display the popup. This is not a perfect example since there may not be multiple features at each location but the task flow is very similar to what I�??m trying to accomplish.  Thanks, Gordon
http://jsfiddle.net/gbooth/Q8Zq5/2/
__Rich_
GordonBooth
Rich - I'm moving into a new office today and will give it go tomorrow- thanks
GordonBooth
Rich - not exactly the solution I was looking for but it got me headed in the right direction. Thanks for taking the time to respond.
