esri.dijit.editing.Editor undoManager
3762
06-05-2012 08:23 AM
YvesCaron
I'm looking for an example to work with the undoManager option in the esri.dijit.editing.Editor or how to implement it.
JianHuang
YvesCaron
Thanks Jian,
It is so simple, here is my solution.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" />
    <title>
      Default Editor
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript">
      dojoConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8">
    </script>
    <style type="text/css">
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        background-color:#fff;
        overflow:hidden;
        font-family:Helvetica;
      #templatePickerPane {
        width:225px;
        overflow:hidden;
      #panelHeader{
        background-color:#92A661;
        border-bottom: solid 1px #92A860;
        color:#FFF;
        font-size:18px;
        height:24px;
        line-height:22px;
        margin:0;
        overflow:hidden;
        padding:10px 10px 10px 10px;
      #map {
        margin-right:5px;
        padding:0;
      .esriEditor .templatePicker {
        padding-bottom:5px;
        padding-top:5px;
        height:500px;
        border-radius:0px 0px 4px 4px;
        border:solid 1px #92A661;
   .undoButtons{
     width:50%;
     margin-left:auto;
     margin-right:auto;
     padding-top:4px;
   .undoIcon {
     background-image:url(images/undo.png);
     width:16px;
     height:16px;
   .redoIcon {
     background-image:url(images/redo.png);
     width:16px;
     height:16px;
   .undoGrayIcon {
     background-image:url(images/undo_gray.png);
     width:16px;
     height:16px;
   .redoGrayIcon {
     background-image:url(images/redo_gray.png);
     width:16px;
     height:16px;
      .dj_ie .infowindow .window .top .right .user .content,.dj_ie .simpleInfoWindow .content {
      position:relative;
    </style>
      dojo.require("esri.dijit.editing.Editor-all");
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.SnappingManager");
      var map;
      function init() {
        //snapping is enabled for this sample - change the tooltip to reflect this
        esri.bundle.toolbars.draw.start = esri.bundle.toolbars.draw.start +  "<br/>Press <b>CTRL</b> to enable snapping";
        esri.bundle.toolbars.draw.addPoint = esri.bundle.toolbars.draw.addPoint +  "<br/>Press <b>CTRL</b> to enable snapping";
        //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
        //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
        //for details on setting up a proxy page.
        esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
        esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        var extent = new esri.geometry.Extent({
          "xmin": -8576501,
          "ymin": 4705377,
          "xmax": -8574612,
          "ymax": 4706867,
          "spatialReference": {
            "wkid": 102100
        map = new esri.Map("map", {
          extent: extent
        dojo.connect(map, "onLoad", function() {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
        dojo.connect(map, "onLayersAddResult", initEditing);
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        var operationsPointLayer = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/FeatureServer...", {
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"]
  undoManager = new esri.UndoManager({maxOperations:8});
        dijit.byId("undo").set("iconClass","undoGrayIcon");
  dijit.byId("redo").set("iconClass","redoGrayIcon");
  dojo.connect(undoManager,"onChange",function(){
              //enable or disable buttons depending on current state of application
              if (undoManager.canUndo) {
                dijit.byId("undo").set("disabled", false);
                dijit.byId("undo").set("iconClass","undoIcon");
              } else {
                dijit.byId("undo").set("disabled", true);
              if (undoManager.canRedo) {
                dijit.byId("redo").set("disabled", false);
                dijit.byId("redo").set("iconClass","redoIcon");
              } else {
                dijit.byId("redo").set("disabled", true);
         //listen for the undo/redo button click events
         dojo.connect(dojo.byId('undo'), 'onclick', function(e) {
    console.log("Je undo ", undoManager);
          undoManager.undo();
         dojo.connect(dojo.byId('redo'), 'onclick', function(e) {
    console.log("Je redo ", undoManager);
          undoManager.redo();
        map.addLayers([operationsPointLayer]);
        map.infoWindow.resize(400, 300);
      function initEditing(results) {
  console.log("initEditing =>", results);
        var featureLayerInfos = dojo.map(results, function(result) {
          return {
            'featureLayer': result.layer
        var settings = {
          map: map,
          layerInfos: featureLayerInfos,
    enableUndoRedo: true,
    undoManager: undoManager
        var params = {
          settings: settings
        var editorWidget = new esri.dijit.editing.Editor(params, 'editorDiv');
        var options = {snapKey:dojo.keys.copyKey};
        map.enableSnapping(options);
        editorWidget.startup();
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
      </div>
      <div data-dojo-type="dijit.layout.ContentPane" id="templatePickerPane" data-dojo-props="region:'right'">
        <div id="panelHeader">
          �?diteur
        </div>
        <div style="padding:10px;" id="editorDiv">
        </div>
     <div class="undoButtons">
                <button id="undo"  data-dojo-type="dijit.form.Button" data-dojo-props="iconClass:'undoIcon'"></button>
                <button id="redo"  data-dojo-type="dijit.form.Button" data-dojo-props="iconClass:'redoIcon'"></button>
     </div>
      </div>
    </div>
  </body>
</html>
KevinGooss
so you are able to undo/redo edit operations that involve feature geometry changes?
How does it track what was done during each edit in order to rollback?
YvesCaron
This is done by the esri.UndoManager class
