Dynamic Layer Parameter
1440
08-22-2012 06:24 AM
sapnas
I'm working on some of the wpf sample codes and in one of the sample code the application utilizes dynamic layer. I browsed to the dynamic layer url (http://servicesbeta4.esri.com/arcgis/rest/services/USA/MapServer/dynamicLayer) from internet explorer and passed in the following layer parameter. Clicking "get dynamic layer" button causes 'layer' param invalid error. I followed the instruction from http://resources.arcgis.com/en/help/rest/apiref/dynamicLayer.html link and did not find any issue. Am I missing any attributes in the layer parameter.
[HTML]
{"source":{
"type":"dataLayer",
      "type": "dataLayer",
      "dataSource":
         "type": "table",
         "workspaceId": "MyDatabaseWorkspaceIDSSR2",
         "dataSourceName": "egdb.DBADMIN.USLakes"
[/HTML]
TanuHoque
here is the correct syntax:
{     "source": {         "type": "dataLayer",         "dataSource": {             "type": "table",             "workspaceId": "MyDatabaseWorkspaceIDSSR2",             "dataSourceName": "egdb.DBADMIN.USLakes"         }     } }
TanuHoque
XuejinRuan
Hi Tanu,
I have a table with a few columns as below:
It will return proper response when I use the following syntax:
{"source": {
 "dataSource": {
  "oidFields": "ObjectID",
  "query": "SELECT * FROM dbo.test2_datetime2",
  "type": "queryTable",
  "geometryType": "esriGeometryPoint",
  "workspaceId": "can_2023"
However, if do not use SELECT *, instead, if I include spatial column name in my select statement, it will return an error:
Do you have any idea what is going on?
Thank you!
