Calculate the orientation of polygons
11937
5
08-05-2012 10:01 PM
KlausKlaassen
I want to calculat in what geografic direction (north, east, etc) polygons are geared.
Is this possible?
Thanks for answer.
JoelCalhoun
There is also the Calculate Polygon Main Angle tool.
Though I believe you need to add an angle field to your polygon layer first.
Joel
DanLee
by Esri Regular Contributor
You can use the Minimum Bounding Geometry tool with the RECTANGLE_BY_WIDTH to get the ORIENTATION of the bounding rectangle, which is a good estimate of the orientation of a polygon.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000003q000000
The output contains the ORIG_FID, which can be joined with the input polygon to transfer the ORIENTATION field, using the Join Field tool.
JoelCalhoun
Joel
DuncanHornby
MVP Notable Contributor
Joel,
Did not know about this tool but it's worth mentioning that it is only available for people with ArcEditor or greater.
Duncan
DanPatterson_Retired
perhaps the Minimum Area Bounding Rectangle from this
http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=3D230972-1422-2418-34A5-2F3FF...
will get you started, it works at all license levels
DanLee
I just want to clarify:  both RECTANGLE_BY_WIDTH and RECTANGLE_BY_AREA options in Minimum Bounding Geometry tool are available at all license levels.
