ArcGIS Pro
ArcGIS Survey123
ArcGIS Online
ArcGIS Enterprise
Data Management
ArcGIS Experience Builder
Geoprocessing
ArcGIS Web AppBuilder
ArcGIS Dashboards
ArcGIS Field Maps
ArcGIS Spatial Analyst
All Products Communities
Education
Water Resources
State & Local Government
Transportation
Gas and Pipeline
Water Utilities
Roads and Highways
Telecommunications
Natural Resources
Electric
Imagery and Remote Sensing Insights (IRIS) COP
All Industries Communities
Python
JavaScript Maps SDK
Native Maps SDKs
ArcGIS API for Python
ArcGIS Pro SDK
ArcObjects SDK
Developers - General
ArcGIS REST APIs and Services
ArcGIS Online Developers
Game Engine Maps SDKs
File Geodatabase API
All Developers Communities
Comunidad Esri Colombia - Ecuador - Panamá
ArcGIS 開発者コミュニティ
Czech GIS
ArcNesia
Esri India
Europe
Comunidad GEOTEC
Asia Pacific
Americas
GeoDev Germany
ArcGIS Content - Esri Nederland
All Global Communities
User Groups
Services
Community Resources
Events
Learning
Networks
ArcGIS Topics
View All Communities
ArcGIS Ideas
GIS Life
Community Resources
Community Ideas
Show
only
Search instead for
Home
Geoprocessing
Geoprocessing Questions
Calculate the orientation of polygons
Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
Translate Now
Subscribe
11334
08-05-2012 10:01 PM
KlausKlaassen
10:01 PM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I want to calculat in what geografic direction (north, east, etc) polygons are geared.
Is this possible?
Thanks for answer.
Solved!
Go to Solution.
Tags
(3)
Tags:
_geoprocessing
analysis
gp
Reply
Kudos
All Posts
Previous Topic
Next Topic
JoelCalhoun
08-06-2012
09:26 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
There is also the
Calculate Polygon Main Angle
tool.
Though I believe you need to add an angle field to your polygon layer first.
Joel
Reply
Kudos
DanLee
08:28 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can use the Minimum Bounding Geometry tool with the RECTANGLE_BY_WIDTH to get the ORIENTATION of the bounding rectangle, which is a good estimate of the orientation of a polygon.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000003q000000
The output contains the ORIG_FID, which can be joined with the input polygon to transfer the ORIENTATION field, using the Join Field tool.
Reply
Kudos
JoelCalhoun
08-06-2012
09:26 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
There is also the
tool.
Joel
Reply
Kudos
DuncanHornby
MVP Notable Contributor
08-14-2012
03:28 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Joel,
Did not know about this tool but it's worth mentioning that it is only available for people with
ArcEditor
or greater.
Duncan
Reply
Kudos
DanPatterson_Re
tired
08-14-2012
04:32 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
perhaps the Minimum Area Bounding Rectangle from this
http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=3D230972-1422-2418-34A5-2F3FF...
will get you started, it works at all license levels
Reply
Kudos
DanLee
08:00 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I just want to clarify: both RECTANGLE_BY_WIDTH and RECTANGLE_BY_AREA options in Minimum Bounding Geometry tool are available at all license levels.
Reply
Kudos
Post Reply
