Make Feature Layer Tool not honoring the selection of fields to make visible
1109
07-17-2012 03:37 PM
HarryBowman
I wanted to create a feature layer in a model that only had certain fields in it, but the output had all the fields anyway, which created a mess - renaming and deleting fields in field maps by hand. Is there some trick to getting this to work properly? I keep running into surprise gotchas.
SolomonPulapkura
Since the feature layer is something that exists only in-memory, I would extend the model to actually write the feature layer to disk. You will probably then get the desired results.
