input many feature
1287
07-17-2012 09:22 AM
mariangalie
Hi!
[ATTACH=CONFIG]16169[/ATTACH]
   In this model builder I want to add more feature classes without opening "edit model" every time, like I can add to Union tool.
Thanks!!
JonathanQuinn
Esri Notable Contributor
The variable type that allows that type of input is called a "value table."  An easy thing to do is right click on the Union tool in Modelbuilder, go to Make Variable > From Parameter, and add the "Input Features" as a variable.  Right click on the Input Feature variable, make it a parameter, and you'll have your input value table when you open up the model as a geoprocessing tool.
JonathanQuinn
mariangalie
Thank you so so so so much!!!  >:d<
