Launch ArcMap with applying definition query to layers
1302
07-02-2012 09:59 AM
DahaeHwang
Hi there,
I wonder if it is supported to open a map document (launch ArcMap in WMX) with applying some definition queries to certain data layers?
The job step will open a pre-stored map document, but the values for definition queries should be dynamic (i.e. [JOB:ID]).
Is this supported in any job step type..?
Any insight or help on this would be really great.
Thank you.
KevinBedel
Hi Dahae,
Currently this is not supported, but we are investigating adding this for future releases.
KevinBedel
Hi Dahae,
FraserHand
Occasional Contributor III
Hi There,
This would be possible to achieve if you were willing to split it into a couple of steps. If you wanted to apply definition queries to a map before opening you could do the following:
Firstly have a step that runs a python script (LaunchGP), which can utilise arcpy.mapping to manipulate the layers within the map - including adding a definition query to a layer. You could then either resave the map document or save it as a new map with the job number. Note that you can pass tokens through to the python script.
Then you can have a second step which launches the newly saved map document with the definition queries applied (LaunchArcMap).
Fraser
