Import in Vue
1081
5
05-22-2012 09:20 AM
mountaineerhill
I use CE 2011 for Vue. I have modelled my first city aligned with terrain. I have exported the terrain as VOB and the city models as VOB seperately. After importing in Vue I can see terrain and city, but the city isn't aligned to the terrain. How can I import terrain and city fully aligned like in CE ? So it seems like a pain to align it manually !
Thanks in advance for your answers from a newbie
mountaineer
MatthiasBuehler1
hi !
Try the following :
In the preferences, in the General tab under Object options, deactivate the setting called 'Center Vue objects when loading'.
As far as I remember, this places all the objects in the same spot from where you can move them up all together.
Lemme know. 😉
matt
mountaineerhill
I have deactivated this option in Vue now, but with no success. The houses are always centered at the terrains center point, BUT have CORRECT dimensions in X, Y and Z-direction. So as I have tried to move the houses manually and after time consuming moving operations they align to the terrain more or less well.
I have also tried under CE Export options > Misc Options > Global Offset > Center, but also without success.
regards,
mountaineer
MatthiasBuehler1
hi ..
- on which Vue version are you ?
- as I remember, there's also a center option on the vue vob import dialog, does this one help ?
- do you have to move individual buildings or are all buildings in 1 vob (there's export options for this in Cityengine) ?
If you'd like for a test, if my inputs do not help you, I could issue you a Time Limited Full License with Exporter, so you can test other formats such as obj which may behave better. This may then become a reason why to switch to CityEngine BASIC.
Let me know. PM if you like.
cheers !
matt
mountaineerhill
- I use Vue 10
- I have tried nearly all possibilities > center on import has no positive effect on placement
- all near buildings are exported as one VOB object
Do you have another advice ? Otherwise I would contact you with PM for the test version of CE Basic.
Regards,
mountaineer
MatthiasBuehler1
hi ..
sadly I don't have Vue10, so I cannot test myself.
can be they have changed something in Vue10 which worked in 9 ..
well, just PM me, ok ?
sry I can not help further atm.
matt
