identify widget
830
05-05-2010 07:36 AM
PaigeBaldassaro
I am using the javascript identify widget. However, I am adding and removing layers on my map dynamically. I need to know how to add/remove map services. Or, disable a service if their is no corresponding layer. At this time, even with the layer option set to Visible, it will still identify a layer after it's been removed.
Paige
by Anonymous User
Not applicable
i suggest you that you can build your own identify dialog, that is easy to modify and maintance.
