Missing Title: 11153
1605
05-03-2010 12:46 AM
tongkimongki
I have a problem in installing ArcGIS API for JavaScript Library.
My environment : IIS 7 and Windows Vista Bussiness SP 1.
I just cant make the Test Code to work. I have followed all the instruction but still cant make it work
thanks
by Anonymous User
Not applicable
Original User: JUngerer
What error(s) are you getting with it?  Have you tried running the test case in Firefox and IE both?  I've noticed that the test case has issues in IE sometimes.  If running Firefox, what does Firebug (add-on) tell you?  Firebug is a way to debug Javascript in the browser and it's also helpful for tracking your application's requests.  Check the NET tab and see if anything flags with red text.
tongkimongki
the error was "dojo is undefined"... but it was caused by my Notepad for messing the code in one of the file .
Its working fine now.
thanks for the response
